Config file creation - This is insane!
I am successfully creating and reading a config file with the method shown on the attached jpeg. It works fine, but that seems like a lot of code to write 7 scalers and read them. I'm probably overlooking something simple. Can someone give this a look and tell me if that's the "correct" way of doing it?
Richard
Message 1 of 9
(3,697 Views)
"Broken Arrow" wrote in message
news:<506500000008000000CA490000-1021771306000@exchange.ni.com>...
If you think it's tough with 7, try it with 50 or so ;). Send me an email
and I have some examples that will help you simplify things. The trick is
basically to use references.
Justin Goeres
Message 2 of 9
(3,699 Views)
Justin, how do I find your email address within the forum?
Richard
Message 6 of 9
(3,698 Views)
news:506500000005000000977A0000-1021771306000@exchange.ni.com...
Should be able to just do a "reply via email."
Or you could just use jgoeres@indioNOSPAMsystems.com. 😉
(remove the NOSPAM part)
Message 7 of 9
(3,697 Views)
One approach would be to store multiple parameters on one line.
You then have fewer keys:
RinseSettingQuantities=bkPulses,bkDuration, ...
RinseSettingValues=5,30.0, ...
That could be easier, especially if you always write or read all values
to the file at one time.
Best, Mark
Message 3 of 9
(3,697 Views)
You can joining your scalers into array and then writing these values inside for-loop. There are two ways - you can storing item names for ini file in the separate array, or getting item names from properties.
See attached files.
Message 4 of 9
(3,697 Views)
Excellent idea. I rarely consider using arrays due to hearing and reading that you should keep your data "as flat as possible", but there's got to be a trade off eventually. I'm using 7 keys to read/write 7 scalers - your examble uses one!
Richard
Message 5 of 9
(3,697 Views)
I am wondering if you can explain how you code your example above..."Storing multiple parameters on one line". Also I am trying to store an array of value, can you suggest an easy way of doing this.
Message 8 of 9
(3,697 Views)
YES THAT'S INSANE! 😉
Take a look at the Variant Configuration File IO library of the OpenG Toolkit. This library allows you to simply wire a cluster of data into a single VI, and the data names of the cluster elements will be used as the INI entry keys names. You can download this library (named variantconfig) here. variantconfig has some dependencies on other libraries of the toolkit, so you should probably just download "all_packages".
Good luck,
-Jim
Message 9 of 9
(3,697 Views)
