Config. file in Labview
I have a configuration file which has string as well as numbers.Config. file has data of  10 motors with encoder reading,temperature,card information and so on.  I would like to  use the data in config. file  for  different motor movements. If I use string function then everytime i have to convert string in to number and while saving file number in to  string. In doing this conversion  I lost the accuracy as well  I think this is not the correct procedure.  Can any one suggest me how I can overcome this problem. If you need code with config file I can post or send.
kane
Room No 22 Building Indus-2
Raja Ramanna Centre for Advanced Technology
Indore 452013(India)
(3,893 Views)
hi RRCAT,
 Basically config file is an ascill file which has fields/keys and initialsing/configuring data...Obviously all the data will be in the form of strings only..The only  one thing as you told that you are losing precision is...using correct format specifiers while reading the data...Please post your config file also in the reply post.
Thanks and regards,
srikrishnaNF
Srikrishna
(3,891 Views)
Have you considered using a binary config file?  You won't be able to edit the config file using a text editor, but you won't lose any precision and the file size remains reasonable.  How much precision are you looking for?
Cheers, Matt
(3,862 Views)
Write Key accepts a "precision" input.
Have you tried using that?
Ben
(3,853 Views)
Why are you using a string type?  As Ben implied, you should be using a DBL type with your config file.  Then you can specify the precision.
- tbob
Inventor of the WORM Global
(3,843 Views)
