Hello I want to configure my serial port using Labview to achive this settings
IRP_MJ_CREATE Serial0 SUCCESS Options: Open
IOCTL_SERIAL_SET_QUEUE_SIZE Serial0 SUCCESS InSize: 2048 OutSize: 500
IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:-1 RM:0 RC:0 WM:0 WC:0
IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS
IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS
IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS
IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS
IOCTL_SERIAL_SET_BAUD_RATE Serial0 SUCCESS Rate: 19200
IOCTL_SERIAL_SET_RTS Serial0 SUCCESS
IOCTL_SERIAL_SET_DTR Serial0 SUCCESS
IOCTL_SERIAL_SET_LINE_CONTROL Serial0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
IOCTL_SERIAL_SET_CHAR Serial0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:d XON:11 XOFF:13
IOCTL_SERIAL_SET_HANDFLOW Serial0 SUCCESS Shake:1 Replace:80000040 XonLimit:2048 XoffLimit:512
IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS
IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR
IOCTL_SERIAL_SET_WAIT_MASK Serial0 SUCCESS Mask: RXFLAG ERR
IOCTL_SERIAL_WAIT_ON_MASK Serial0 SUCCESS
Thank you in advance,
Regards
