Configuration obstacle
I'm attempting to configure a newly installed NI-9237 4 channel wireless unit using the Measurement & Automation Explorer component of LabVIEW but not getting the expected response from the configuration panel.
I have set the laptop Network Connections TCP/IP properties to a unique IP address and then launched the Measurement & Automation Explorer (MAX) application. In selecting the Configuration\Devices and Interfaces\NI-DAQmx Devices - right clicking for 'Find Network NI-DAQmx Devices', the result ends with a "NO Devices Found" response. All physical connections have been verified to ensure connectivity. Even rebooted laptop and restarted the application several times.
What else can I check for or do to get MAX to acknowledge that there is a new wireless device that needs to be configured?
Any guidance is greatly appreciated.
(3,145 Views)
the 9237 is similar to the 9163 as far as setting up the wireless connectivity
Here's a link to the manual.  It looks like the device needs to be hard connected to a network for configuration.
https://www.ni.com/docs/en-US/bundle/372489c/resource/372489c.pdf
Here's a link to a knowledgebase article with common trouble shooting issues for the 9163, again, similar to the 9237 for configuration purposes only.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x5PxCAI&l=en-US
Good Luck!
(3,120 Views)
