Configure FreeView (sound card) in LabView
Hello
How do I configure the sound card version of FreeView in Labview.
Maybe a better question is: how do I setup the sound card as a DAQ
board in LabView?
Thank you
(2,910 Views)
since LV5.1 there is a set of instruments to control Sound Card. They are located in "Functions->Graphics&Sound->Sound" palette. They are practically identical to DAQ VIs and allow you to config and control both sound input and output. You can save and read data not only as numeric arrays but also in WAV format. If you have full duplex sound card you can realize simultaneous input and output.
Good luck.
Oleg Chutko.
(2,910 Views)
