08-12-2015
11:41 AM
- last edited on
12-18-2025
05:39 PM
by
Content Cleaner
In the Configure Timed Loop Dialog Box documentation we are told that:
Period—Specifies the amount of time that elapses between two subsequent iterations of the Timed Loop. The unit of the period changes depending on the timing source you select in Source Type.
But nowhere are we explicitly told what the unit of Period is. This ought to be made explicit for each of the possible Loop Timing Source Types. I'm guessing that if I select 1 kHz Clock the unit of Period is 1 millisecond. But I shouldn't have to guess!
08-12-2015 11:46 AM
I agree. You should post this over in the LabVIEW Idea Exchange.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-12-2015 11:52 AM - edited 08-12-2015 11:52 AM
@James Morris: Done.
