Configure sampling rate of PXIe-5162
Hi, I have a 4ch PXie-5162 digitizer. I want to use only 2 channels. From the datasheet I read that with 2 channels enabled it should sample at 2.5GS/s but labview says all the time that max is 1.25GS/s.
I put a separate  "niscope Configure Vertical .vi" and disable here  the channels I do not use but it takes no effect.
How to configure the digitizer to get max sample rate with 2 channels?
(3,168 Views)
I think I have the answer. When  sampling 2 channels only, channels specified as active have to be 0 and 2, then I get 2.5GS/s. When I select 0 and 1, sample rate is 1.25GS/s.
(3,106 Views)
Hi!Do you know how to store sampling data at high sampling rates(1.25GS/s)
(1,105 Views)
I have a PXIe-5162(2ch)
(1,104 Views)
