You heard wrong - at least for the board you are using. Some digital I/O on some boards can only be configured on a port basis. If you look at the specifications for the 6229, you will see that it states that 'Each terminal is individually programmable as input or output'. That measn you can do exactly what Mike said with the DAQmx Create Channel.
