Configuring Database for logging to citadel Database using shared variable engine
Hello All,
I have two systems with me here, one with LabVIEW 8.5 and one with LabVIEW 8.6, I'm using Shared Variables in my code and I am Logging to citadel Database. In a PC with LabVIEW 8.5, I am able to Log Data to citadel Database, but with the same code I am not able to Log Data from the PC with LabVIEW 8.6. Both the PC's have Database Installed and the connection with the Database Exists when I test connection with database through control panel. I would Like to know any configurations (in LabVIEW or in code or in Database or in PC) that have to be done for Logging to Database because the PC with LabVIEW 8.6 was added recently and the code was upgraded to 8.6.
(2,725 Views)
It was due to a dll in LabVIEW, a dll named nitaglv.dll
Now I have a issue with Data Logging from the EXE, once the shared variables are deployed programatically from the EXE the Data Logging stops,
can I get any input on this issue..???
(2,648 Views)
