Configuring Digital I/O as bidirectional line in PCI-6229
I have an M Series PCI-6229 card. I have two issues with it:
1. I need to communicate to a device using the specified commands & responses in terms of digital bit patterns. This requires to configure a digial line as output when I want to send the digital data to this device. After this, i need to configure the same digital line as an input as to receive the digital data from the device.
I could not find this option for M Seires card, can some one help? If this option is there for PCI-6229 card, then what is the latency while configuring digital line from output to input & vice-versa?
A VI to do it shall be appricated.
2. I need to implement I2C bus using digital lines of M series card. Using this I2C bus I need to give command & read an eeprom contents.
How many digital lines do I need to perform this? If any body has written driver in LabVIEW, can you pls. send it?
Thanks in advance.
With best regards,
Nirmal Sharma
(2,676 Views)
Look out for the reply here
Chetan K.
(2,655 Views)
