Configuring PXI-7831R as analog input
Hi
I am new to NI PXI, thought i have previously worked on Labview. My PXI chassis has two analog output modules (PXI-6713 and 6733), one PXI-2501 FET multiplexer, one PXI-4070 DMM,PXI-8464 CAN , a IEEE host adapter module and PXI-7831R (reconfigurable I/O) module.
I could succesfully configure my components using MAX.
The problem i am exactly facing is "taking in analog input's" using my PXI-chassis.
With the above modules, i guess i can only use the 7831R module as analog I/O.
But the problem is the 7831R is an FPGA module and it is not shown under DAQmx.
So, where can i exactly find the 7831R analog in pin's (in the labview GUI) and how to use them in my VI block?
Do the next version's of labview provide a DAQ interface even for 7831R? (my version of labview is 8.2.1).
Kindly help me in solving my problem.
(3,227 Views)
Accepted by topic author Vijay Chand
You need the FPGA module.
(3,214 Views)
