Configuring PXI 8184 controller to synchronize to SNTP server
I've been trying to syncrhronize a PXI 8184 controller to a SNTP server and have not succeded...
I read that PXI does not natively support SNTP synchronization. Most forum threads I found apply only to compactRIO controllers running the VxWorks operating system, but what about PharLap ETS real time OSs? Is there a way to make this work with the current hardware?
Thank for your help.
Gustavo
(3,382 Views)
Hi Gustavo,
Really its not officially supported by PXI, but I can found some examples using PXI.
http://zone.ni.com/devzone/cda/epd/p/id/1487
http://zone.ni.com/devzone/cda/epd/p/id/1558
Abel Souza
Applications Engineering
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,245 Views)
I have a windows based PXI 8108 controller. I need SNTP server on this machine in order to do time sync with my client machine with SNTP client installed on it.
Currently I have NTP server and unable to perform the time synch. What steps must I follow to have SNTP server. Else, is there a possibility to have NTP server but perform a time synch with SNTP client.
Regards
Sreedhar
(3,220 Views)
