11-20-2009 09:36 AM
I have a anemometer(wind speed meter) with a manufacturers driver which i have used to configure the instrument to send a measurement every 100ms. The instrument has a digital output and connects to the computer through a USB port. However, in labview there is no recognised driver for the instrument so i was forced to use the instrument I/0 assistant. This only collected measurements every ten seconds which is nowhere near the 100 ms required and doesnt appear to be talking to it correctly. I know the instrument is configured properly because the instrument driver shows it working fine.
Is there anyway i can use the manufacturers driver through labview? Or will i be forced to convert the instrument to an anlogue output and connect it through my daq card?
11-20-2009 10:34 AM
