Configuring input/output of NI9401 in labview FPGA
I am very new to the Labview FPGA. I am actually trying to implement the very first example introduced by NI for learning Labview FPGA. I have to connect an input from one NI9401 to an output from the other.
However, when I drag and drop the input/output units, they both act as inputs:
I have also changed the propties of one of the NI9401 to act as output. But the issue still persists.
This is the example I am trying to build.
I will appreciate any suggestion.
https://www.youtube.com/watch?v=mv112V-P030&index=1&list=PLbCk9hRe-ziECXQjE--fN29C_kcx7CHnA
(3,845 Views)
Accepted by topic author Amin1
Right-click on the output node and select "Change To Write"
(3,833 Views)
