Configuring pci 6503 for sherlock software from dalsa
Hi!
We wanted to use digital I/O with a vision system software -- Sherlock from Dalsa.
We bought a PCI 6503 card from NI.
Through the DAQ assistant we could get the BAR0 and BAR1 addresses which are useful for Sherlock to access the I/O.
The card works fine with the DAQ Assistant of Labview.
Unforunately, the Sherlock software does not think so !!
When I use the BAR0 address, Sherlock does not recognize the I/Os.
When the use the BAR1 address without an offset, it does recognize PortA as an input. However as an output it is ineffective.
With an offset of 01 it sometimes recognizes Port B.
With an offset of 02 it sometimes recognizes Port C.
Has anyone worked with Sherlock and PCI 6503?
Would be nice if I could get some solution. It is downright frustrating.
Tadep
(3,147 Views)
also I want to interface sherlock to labview; have you created some drivers or did you download from internet?
I am trying to build them from an example in visual basic but if I find something of already done it is better. I hope you can help me.
Giuseppe
(2,946 Views)
