Confine mouse movement within boundary
@Sable wrote:
Like this? (please refer to the attached vi done on LabVIEW 2013).
Looks good to me.
0xDEAD
Message 11 of 20
(1,885 Views)
That's it!
I'd make a nice VI for it, maybe make the input rect -1,-1,-1,-1 default, and if the input is default call the null pointer. That way, you have one VI to set\remove the region. Two VI's works too of course.
You can put the clfn to "run in any thread". It's a tiny bit faster, as the clfn doesn't have to wait before execution.
Message 12 of 20
(1,865 Views)
Could you please elaborate "You can put the clfn to "run in any thread". It's a tiny bit faster, as the clfn doesn't have to wait before execution."?
Message 13 of 20
(1,854 Views)
My objective is to confine the cursor within the left pane of the front panel.
I am having some difficulty to do it with my vi. (please refer to the attachment done in LabVIEW 2013).
Can anyone please advise me what am I doing wrong?
- Sable
Message 14 of 20
(1,847 Views)
You need to use the Method "Convert Pane to Panel Coords". Also, make sure that you close the pane references. There is probably still something wrong because I had to subtract 50 pixels from the Panel top position but otherwise it works as you want I think. I attached the VI in 2013 format.
Marc Dubois
Message 15 of 20
(1,836 Views)
Concerning the "Run in any thread", you can configure the Call Library Function Node by right-clicking and selecting "Configure...". In the Function tab, you can select "Run in UI thread" or "Run in any thread". By default, "Run in UI thread" is selected.
If the dll needs to occupy a constant memory space (non-thread safe), you should use "Run in UI thread". Problem is that the UI thread is used for UI operations so it gets called all the time, so the dll call might have to wait for the UI thread to be available, and the dll call might also interrupts another UI operation. There is also the switch time between the current thread and the UI thread.
So when the dll is thread safe, it is better to use "Run in any thread". When the dll is called in the UI thread, the node header is orange and when "Run in any thread" is used, the node header is yellow (see below).
Marc Dubois
Message 16 of 20
(1,825 Views)
Thank you very much Marc. Really appreciate thehelp.
I changed the clip cursor code a little to get it to work without the minus 50 pixels.
Let me know if this makes sense (please refer to the attached vi).
Message 17 of 20
(1,807 Views)
Accepted by topic author Sable
It seems that you got it. You still need to close all the Pane references from the array, even if you don't use them.
Marc Dubois
Message 18 of 20
(1,787 Views)
Closing a Pane, or any descendant of the GObject class, does nothing and is unnecessary.
Reference from Darren Nattinger himself
Message 19 of 20
(1,779 Views)
Thanks a lot for your solution - excellent! It helped me to move the mouse only in a sub-panel and not risk clicks outside of it. Within the sub-panel was a dynamically called vi. Thanks again, Peter
Message 20 of 20
(1,589 Views)
