Congestion on PXI connect
I am trying to reduce congestion on the PXI connect between a hostVI and a FPGA-based VI.  My question is:  Is traffic on the PXI connect caused by a read/writes in the host VI or is it caused by a read/write in the FPGA-based VI?  Thanks.
(3,138 Views)
Basically whenever the FPGA and the host are communicating, you will experience traffic between the two. A write from the host will always correspond to a read on the FPGA and vice versa. Thus you cannot pinpoint traffic to either target.
Why is it that you are trying to reduce this communication? Have you seen adverse effects of congestion causing problems in your application? If so, I might suggest using DMA FIFOs to buffer some of this data such that reads and writes are less frequent but pass more data during an interaction. I hope this information is useful for you. Thanks,
Mike D.
(3,122 Views)
