06-26-2018 12:34 AM
Hey I have been working with new wireless sensor, I am trying to connect this sensor with computer and working with the help of utility software provided by this company which is running on lab-view
But Need to know the alternative way which help to connect the sensor readings while interfacing with particle photon and get the readings connect to Azure IOT Hub which display the dash board of readings of sensors by using web based applications
I have never worked in this kind of implementation, so your leads will be much appreciated
07-20-2018 04:30 AM
The sensor you linked is a wireless one and from their website it shows you how to set it up:
https://ncd.io/long-range-iot-wireless-temperature-humidity-sensor-product-manual/
What is it that you are actually struggling with? and where does the 9209 come into it?
