Connect LabVIEW to Simatic PLC Simulator
Hello everyone,
I'm trying to simulate a process on Siemens PLC Simulator (PLCSim) and LabVIEW and I used NI OPC Server,created the Tags then created the bound variables and when i opened the Distributed System Manager, I couldn't see the tags I created. So I have to Questions:
1- Is it Possible to work with the Simulator Like I do in WinCC as I want to replace my WinCC SCADA with LAbVIEW?
2- if it is possible and not the reason for this Problem, what reason may cause it ?
Thanks in Advane
(6,796 Views)
Thanks very much
since you put this link about nettoplcsim and i tried to connect it many times but in every time it can't be done in the right way.
so please if you have steps to do it, provide me with.
Many thanks
(6,746 Views)
Here are a few resources that I would suggest for connecting an actual PLC to LabVIEW. I haven't used PLCSim, so I can't speak to specific steps for working with that product, however these may be useful:
Developer Zone Tutorial: Connect LabVIEW to Any PLC Using OPC
NI Community Example: S7 PLC TCP/IP Protocol Reference Example
Tim W.
Applications Engineering
(6,725 Views)
