Connect NI9221 to measure the current
I have a doubt, I will like to measure the voltage and the current using NI9221.
When I use a multimeter, to measure the voltage I have to connect it in parallel and to measure the current I have to connect it in series. I try to do the same with the NI9221 but the results of voltage was not ok.
In other words, in the following image, which option I have to use to measure the voltage and the current from the resistance?
(I have tried to get the voltage with the AI1 and the current with AI0)
(3,053 Views)
It's a little bit unclear what you are trying to do. Are you trying to measure the amount of power that is being drawn by a motor? In your diagram, what are the leads coming from your motor? And what kind of motor is it?
In general, if you want to measure the current through something with a voltage module, you will need to measure the voltage drop across a known resistance, and then calculate the current using Ohm's law. Or, if power is your end goal, P=V^2/R.
But, if you let me know what the wires coming from the motor represent, and what  you are ultimately trying to do, I can help you figure out exactly how you should wire your inputs to the NI 9221.
Wes Pierce
Principal Engineer
Pierce Controls
(3,002 Views)
I have tried to get the voltage with the AI1 and the current with AI0. How I have to connect to do that?
(2,966 Views)
