Connect Similink and LabVIEW
Hello guys,
I want to explore a method to connect the Simulink model with LabVIEW. Here is the condition, I have a fully-built model in the Simulink. The function of LabVIEW is more like a real-world linear time-invariant model G(s) that receives input from the Simulink and generates outputs from experiments.  Otherwise, it would be difficult to replicate the entire Simulink model under the LabVIEW environment.
(1,563 Views)
Hi HKUST_Mike
There is an article where you can find the way the guidance how to make connection between LabVIEW and Simulink.
Try to go through that article.
Regards)
(1,508 Views)
