Connect Transonic Systems Flowmeter to Labview
I have an older DAQ card (PCI6036E) that I am attempting to connect a Transonic Systems TS410 to labview version 10... does anybody know if there is a driver for transonic devices?  I know that the hardware should be configured correctly because the flow meter was correctly working on labview 7, but we had to do a reinstall of everything because of a windows problem, so I'm thinking that the problem is related to the drivers.  Thanks!
(3,098 Views)
If there are drivers available they should be listed in ni.com/idnet; I could not find any drivers for a transonic system. This site is a good resource for 3ed party drivers. I am confused as to why you are using a daq card to communicate with an instrument. Usually instruments communicate over serial or gpib and other protocols.
<Joel Khan | Applications Engineering | National Instruments | Rice University BSEE>
(3,074 Views)
