Connect cDAQ Ethernet chassis to a laptop via a router
Is it possible to connect a cDAQ Ethernet chassis (e.g., cDAQ 9185) to a router via wire, and communicate wirelessly with a laptop computer? Thanks.
Ian
(2,431 Views)
Accepted by topic author TulaRen
Yes  It is easiest if all the devices are on the same sub-net, but that is not an absolute requirement.  Wired or wireless, the TCP/IP communication all looks the same to the devices and software.
(2,393 Views)
Excellent! Thank you.
Ian
(2,382 Views)
