Connect flexiforce to DAC
Please would you mind explaining how can I connect the Flexi force sensor to DAC and then to LabVIEW? I tried to connect but I couldn't.
thanks a lot
(910 Views)
I take it "Flexiforce" is a sensor.  Does it "plug into" anything?  Does it output a Voltage, a Current, maybe a string of characters over a Serial Interface?  What is a "DAC"?  Is it a "Digital to Analog Converter" (probably not), or does it stand for "some form of I/O device"?  What DAQ (Data Acquisition) hardware do you have on your PC?  You (probably) need some hardware to plug the "Flexiforce" into, and then connect that hardware to your PC running LabVIEW.
Please provide further details.
Bob Schor
(889 Views)
