Connect multiples variables in a bundle at once
Hello to all,
First of all thanks a lot for reading this post and being able to help.
I have multiples local variables (about 100) and I have to connect them in a bundle.
Connect one by one will be a tedious work...
I would like to know if there is a way to connect them at once.
Thanks a lot.
(2,807 Views)
Hi Alvaro,
The main question is: why do you have ~100 local variables?
Have you considered (typedefined) clusters to organize your data right from the beginning?
IMHO you should start with a (typedefined) cluster and just read/write/replace values in this cluster when handling UI interactions…
(2,800 Views)
I have never use typedefined.
Can you please provide a link where I can start to learn about it?
Thanks a lot!!
(2,782 Views)
Hi Alvaro,
it's all in the help
(2,773 Views)
