Connect pressure transducer and mass flow meter to NI 9923 NI 9207
The output of my voltage pressure transducer have 5 wires( green , red,black,white,silver) , I want to connect similar 7 voltage pressure transducers to my NI 9207.
I believe the wires has to be connected to NI 9923 which is inturn connected to 9207.
Please guide me on how I could do the connections.
I have one mass flow meter as well which has to be connected to one of the current terminals in the module.
Thank you. Appreciate the help
(2,151 Views)
Hi zaqf,
Recommendation: read the manuals of your sensors to learn how to connect them to your DAQ equipment!
(Which comments do you expect for such questions, missing all relevant information? The colors of the wires are completely useless to us!)
(2,143 Views)
Helloo. Hope you are doing well Mr GerdW.
So basically I have 6 pressure transducers with 1-5VDC as output, and I want to connect them to my NI 9923.
My pressure transducer has 5 wires as output now and I want to connect them to my AI +-10V channels in NI 9923 .
I am attaching the picture that mentions what each wire represents on my transducer , and the picture regarding what each channel on my module 9923 represents.
It would be of great help if you could recommend a wiring so that I could move forward.
Thank you so much
(2,087 Views)
Would appreciate it if someone could guide me on this.
Thank you.
(2,050 Views)
Connect like this, power up the sensor using an external 12-28VDC supply and connect +Out and -Out to AI+ and AI- respectively.
Santhosh
Soliton Technologies
(2,046 Views)
