Connect to cRIO
Hi, I would like to ask. I need to connect cRIO from LabVIEW to see folder list. First I need to set username and password because cRIO is locked. How can I do that?
Thanks.
(3,015 Views)
Hi Dano,
you can do that inside MAX or by browsing your cRIO with your InternetExplorer (I hope the needed software parts are installed in your cRIO).
Then you can log in with your account credentials…
(3,010 Views)
