Connecting Keithley 2100 DMM to computer with LabView
For my project, I need to measure the change in resistance of a resistor as it is heated up. I have a Keithley 2100 connected to my computer via USB and have installed LabView, NI-VISA, and the instrument drivers that I found on another forum. When I try to load the VI to "configure 4 wire resistance measurements"  I receive an error message that says "dependency loaded from new path (3 warnings affects 3 callers). I ignored it and I was able to run the VI to take a resistance measurement. However, should this be a concern?
Also, if I want to take continuous resistance measurements over a period of time (as the resistor is heated up), is there a way to continuously run measurements, store the data, and display it on a graph? I'm new to LabView and not sure how to do this.
Thanks!
(6,863 Views)
I wouldn't worry to much about the new paths, the driver was probably saved in a different location.  I think if you run a mass compile on the driver project it will resolve these issue. ( not 100% sure but I think so).
You can use a while loop to continuously store the results and graph the data to a chart.  You will need to put a "wait" in the loop so you are not taking data at the speed of light.
***  Generally speaking *** , open a file outside the loop, store the results during each loop, then close the file after leaving the loop.
Put a stop button inside the loop so you can stop the operation.
Put a *strip chart* inside the loop so you can write data to the chart each iteration and see the updates.
Perhaps put a numeric control inside the loop and attach it to the wait so you can change the length of time between measurements if you want to. (instead of a constant wait period.
You can test your method by using the random number generator in the loop instead of your measurement drivers, divide and conquer eh.
This should get you started.
Mark Ramsdale
(6,856 Views)
You don't mention where exactly you got the driver or where you installed it but since it is a warning message and everything works, you can ignore the message.
Everything you want is possible. Start with the basic LabVIEW tutorial.
(6,855 Views)
Thanks for all the responses! I'm going to go thinrough the tutorial first before I get too far into my project and then work on setting up the loop for contious measurements, and hopefully I'll get it to work. Thanks again
(6,844 Views)
