Connecting LED light to a table, and lights up if a number exists.
I am trying to allow a LED light to be connected to a table or graph and when a constant is reach or if a constant exist in the table, the LED light will light up.
For example, I have random numbers coming into the table or waveform graph, and any number greater than 8 will trigger the LED light to light up.
Can anyone help me.
Thanks!
(4,233 Views)
Just wire the random number generator to the greater than function? A table and a graph are indicators so it's silly to say you want to connect another indicator to them.
(4,226 Views)
Accepted by topic author WillDU
Tables are 2D arrays of strings, so you cannot do math directly. I assume that you have the original numeric array also as a 2D array. Simply use the "greater than" function followed by "or array elements".
(4,219 Views)
This is what I have, how do I go about fixing it. It states that I have connected two terminals of different types.
(4,188 Views)
I just realized what you've said. It worked! Thanks a lot!!!
(4,177 Views)
It's great to see the lightbulb go on here in the forums.  🙂
Unlike in LabVIEW, turning on the lightbulb here in the forums speeds up execution.  😉
Bill
CLD
(Mid-Level minion.)
(4,153 Views)
