Connecting LEGO mindstorms NXT to my computer
I am trying to learn Labview using the LEGO mindstorms NXT robot. I installed Labview 2009 and started working, but when I open the NXT terminal in the NXT module it claims that the NXT is not connected although it is (via USB). Any ideas ? Could this have to do with the fact that I am using Windows Vista ?
(3,157 Views)
You may want to post your question on this board http://forums.ni.com/t5/LabVIEW-Education-Edition/bd-p/460 where a higher percentage of the readers there are using the Mindstorm NXT.
(3,145 Views)
Baty,
As Ravens Fan stated, please post this in the LabVIEW Education Edition Support.
Sam K
National Insruments
(3,116 Views)
This article is intended to indicate the installation and configuration process between LabVIEW and educational robot Lego Mindstorms NXT wirelessly, this will enable LabVIEW developers in having a mobile platform for the development of projects and autonomous robots, we need to install some programs the computer:
https://decibel.ni.com/content/docs/DOC-32448
(2,956 Views)
