08-01-2007 03:44 PM
08-01-2007 04:10 PM
Are you even sure that the instrument supports the *IDN? command? Is it listed in the manual?
The \ code equivalent of CR is \r and the \ code for Lf is \n. You can determine things like this yourself. Create a String control and right click on it and select Hex Display. Enter a hex value (i.e. 0A) and then right click and select '\' Codes Display.
08-01-2007 04:16 PM
08-01-2007 05:27 PM
08-01-2007 05:42 PM
08-01-2007 05:45 PM
08-01-2007 05:54 PM - edited 08-01-2007 05:54 PM
Message Edited by unclefeezus on 08-01-2007 05:54 PM
