Connecting Oracle Database using Oracle Objects for OLE (OO4O)
I try to connect to an Oracle Database using OO4O. First of all every property node/invoke node that I expect to return a refnum to other type it doesn't return. It returns a variant, I need to convert the variant to the refnum type I expect (which is not always obvious), is this the only way to using OO4O??
Ok, but using this I can do selects and call stored procedures. The problem is that for call storing procedures I need to put in the block diagram the property node OraDatabase(Parameters) and after this property node is in the block diagram I can't close anymore the session at database (until close the application). I removed all the parameters, I close reference to parameters, database, and session, I call invoke node close database. I don't know what more I can do, and the session in the database always still open (inactive but still exists).
Do you have any ideas? Anybody have experience with OO4O?
I need some help.
Attached Vi that shows the problem (this only happens using the OraDatabase(Parameters) property node)
(4,074 Views)
Hello IDILIO.
Unfortunately, we don't have enough experience in OO40 to help you. I would suggest you to rather contact Oracle and I think they will be able to give you more informations about Oracle activeX class.
Regards
(4,001 Views)
This problem is specific in Labview (I can do the code in other language like vb.net and it works ok).
So I don't think Oracle can help on this.
There are some people that already used OO4O in labview, i'm sure that they know what i'm doing wrong....
(3,995 Views)
