Connecting Redlab-TEMP with labview for measuing thermocouples
I want to connect RedLab USB-TEMP with Labview to measure thermocouples. I have installed LV drivers but it is not working. Please provide me some suggestions. Thank you.
(2,629 Views)
Hi Jahra,
did you ask RedLab why their LabVIEW drivers don't work?
(2,616 Views)
Thank you so much for your reply. I didn't ask RedLab.I can ask if you suggest. Please let me know if you have any other solutions.
Best Regards,
Jahra
(2,608 Views)
Hi Jahra,
The manufacturer of your hardware should be the first you ask…
Read the manual that came with your hardware: it should explain the requirements!
"Not working" is a bad, very bad error description: when you want specific help you should provide specific information…
(2,602 Views)
Have you managed to connect the Redlab Device?
Best regards
Rene
(873 Views)
