Connecting UMI-7774 to KEB Motor Drive
* i post this message in the Motion Control and Motor Drives  board but i cant see any activity on that board, i'll apriciate any help from you here *
I'm having problems to connect my Servo motor: KEB, With Combivert F5 Motor Drive.
I have the manual and all the pin assigment for this motor drive but i cant run my servo from MAX.
I'm using : LabView 8  + Max 8
NI Motion and  Motion Assistant  1.3
I attach one pdf file with 2 pages,  the pin assigment of my KEB  Motor  Drive  (Model: Combivert F5)
This URL for the Model from KEB Website : http://www.keb.de/common/catalogues/C_vert_F5/0000000-91F5-07-03.pdf
the other page in my attached file is the umi 7774  AXIS 1 pin assigment.
I will appriciate any help if someone can help me and describe to me how i should
connect my umi 7774 FeedBack & Control pins to the pins of my  KEB-CombivertF5 Motor Drive.
Thanks in advance.
Mor
(3,114 Views)
Mor,
I have replied to your posting in the Motion forum, which can be found through the link below...
http://forums.ni.com/ni/board/message?board.id=240&message.id=3325
Lorne Hengst
Application Engineer
(3,098 Views)
