Connecting WLS 9162 module to laptop
Sir
 I am trying to connect my dell laptop to WLS 9162 module with ni9472 daq module.
  for that I ueds following steps
  open measurement and automation
then explored  devices and interfaces
 then explored network devices
 then I tried to find out devices , it is not listing the given wls module.
 tried so many times.
 before doing this  I  ensured  network card is configured to obtain an IP address automatically, lease help for this issue
  regards
fsk
N.B throgh the netwok card I am getting internet
(2,483 Views)
Hi FSK,
I'm currently working with a 9163.
1) I had to do a hardline (ethernet cable) connection to the 9163 before using my wireless link.  This was necessary for configuration.
2) Over the hardline, I configured the 9163 with a static wireless network address (as I had no server on the network).  I used 10.2.2.101 with subnet 255.255.255.0
3) On my laptop, via control panel, network connections, wireless, properties, TCP/IP, I configured my laptop with a static wireless network address.  Here I used 10.2.2.201 and subnet 255.255.255.0.
4) Finally from my laptop, I made a manual wireless connection to the 9163.  NIDAQmx saw the device.
NOTE:  The NI application engineer recommended using a router for higher throughputs.  So we obtained such a router.  I configured it with a static IP as well.  Everything works, even at the 51,200hz sample rate.  The router could be configured to hand out IP addresses, in which case you would undo the static IP configurations, but we have no need of such a dynamic system.
All the best,
Terry
(2,467 Views)
Hi Terry
I tried for the  same as you said. But still its is not detecting
regards
FSK
(2,446 Views)
