Connecting database file
Dear friends:
How can I open a databese file in Database Toolkit?! I have a Sequence Data.mdb, but I can't to open it...
Thank you.
(3,779 Views)
You need to create a connection string, a UDL file or a DSN file.
This is done in Control Panel>>Administrative Services>>ODBC Data Sources.
Try looking at the examples in the example finder (Help>>Find Examples) to see more.
___________________
Try to take over the world!
(3,776 Views)
Hi tst:
I'm new in Database... I know how to create a *.mdb file, but I don't know to create a connection string, a UDL file or a DSN file... please help me.
(3,752 Views)
Read my last answer - go to where I mentioned and read the help there. You can create a DSN file pointing to your DB. Also, LOOK AT THE EXAMPLES.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
(3,747 Views)
Hi Clecio,
under control panel > Administrator Tools>Data Souces
Open ODBC Data Source Administrator> File DSN
The rest is straight forward.
As TST suggested read the examples, also skim the Database connectivity manual. It pays dividends
Like you, I  have just started in databases, only 2 hrs for the basic functionality.
Xseadog.
(3,739 Views)
You can also go here.
This is the LV Database connectivity toolkit manual, which has some very good information in it.  If you are looking for some more advanced queries using sql, try these links.
sql introduction
sql examples
Kenny
Kenny
(3,733 Views)
