Connecting dynamic data to AND gate
The program compares readings from a thermocouple to a constant. The outputs from the greater than are fed into a AND gate. However, though one of the inputs can be connected as dynamic data to the input port of the AND gate. When the same data from the other DAQ is sent, it gives an error. Interchanging the ports also gives the same error.
Can I use some kind of dynamic to boolean converter to counter this? The output of the AND gate is then fed into the DAQ output port.
Thanks.
(2,888 Views)
Accepted by topic author SohamSaha
Hi
try something like the logic shown in the attached pic.
let us know if that is what you were lookign for.
Regards
Freelance_LV
TestAutomation Consultant
(2,884 Views)
