Connecting mathscript node to continous transfer function in CDS loop
PID speed control of DC motorPID speed control of DC motor
Could you please tell me how the mathscipt node has been connected(indicated by the pink arrow) to the continuous transfer function as shown in the diagram?
The output of PID is connected to the TF in which I have defined the model of DC motor. When I try to connect the mathscipt node to the TF, I am unable to find another input node.
Kindly help me out.
Ramya M.A
(4,576 Views)
Hi ramyana,
It has been connected by the pink wire.
(Atleast I guess so, but you can verify this using the AutoCleanup function from the menu…)
(4,533 Views)
Hi GerdW,
Thanks for your reply. Yes that's right. It has been connected by the pink wire. But the transfer function is of continuous type with just one input. So how is it that the pink wire is also connected to the transfer function along with the output of PID?
Ramya
(4,529 Views)
Accepted by topic author ramyama
Hi ramyama,
according to this old LabVIEW help this function has three inputs…
(4,525 Views)
Ok got it. Thank you.
Ramya
(4,515 Views)
