Connecting to a MS Access database with DB Tools Open Connection VI
Hi all,
So I'm having issues with accessing a password protected database.  in this case my Password is "Password" as I'm just trying to get it to work.
Some background.  I've connected MS access databases to LabView a few times, but I have never used a password and it seems to be giving me a few problems. I'm wondering if there is some formatting that I have to do to get it to work. and I've tried a few variations like adding an "admin" User ID and putting things in quotes and ' to no avail.  Again if I take the password out everything works fine.
In any case, I made a sandbox VI to show how I have set it up with a dummy database password is Password.  (Looks like I can't attach the MS Access file so oh well).
Any help or suggestions would be appreciated,
Chris
I get error -2147217843:
NI_Database_API.lvlib:DB Tools Open Connec (String).vi->sandbox.vi<ERR>ADO Error: 0x80040E4D
Exception occured in Microsoft JET Database Engine: Cannot start your application. The workgroup information file is missing or opened exclusively by another user. in NI_Database_API.lvlib:DB Tools Open Connec (String).vi->sandbox.vi
(1,269 Views)
Accepted by topic author none010010
There is a post on this very LabVIEW Forum, "Connecting to an access database", posted October 18, 2016, which discussed this problem and appeared to come to a solution that worked.  I found it by doing a Web search for "labview access database password".
If you follow this post, and find that it is a solution, please mark this post of mine as the "solution" to your question, to help others who might have similar questions.
Bob Schor
(1,236 Views)
Thanks after following the Document at the end I got it to work.
(1,205 Views)
