Connecting to a RS-232 scale
I am having trouble connecting to a scale that uses a rs-232 serial cable. (myweigh i601)
I can communicate with it using hypeterminal, but when I try to communicate using MAX, I get the error message
Error opening resource:
ASRL1::INSTR
VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
I have limited experience using serial communication with labview, so any direction to getting this up and running would be great.
(3,003 Views)
ASRL1::INSTR
Are you still running Hyperterminal when you try to run your VI?  Is anything else trying to use your serial port (MAX, third party application, etc.)?  Only 1 program can access the port at a time.
(2,996 Views)
Only labview is running
(2,967 Views)
