Connecting with Data Acquisition
I'm doing a car model which control by pda. Now, I'm trying connect data acquisition as input signal to my h-bridge circuit. But, the problem i found is the supply from the data acquisition are 3.3V and 0.01A and i only need 1.4V and 0.2A to drive the h-bridge. can anyone give me an idea how to fix this issue?
Thanks.
Message 1 of 10
(4,796 Views)
Hi Wyatt,
from your numbers I would guess you need a power supplySmiley Wink
While the DAQ may provide the needed voltage (using a simple resistor network or a low drop voltage regulator) it will definitely not provide the current you need. But it should be sufficient to drive a relais or a transistor to switch a pwoer supply...
Message 2 of 10
(4,786 Views)
Hi Gerd,
Thanks for reply. So, do u mean that i need another power supply for the input signal for the h-bridge?  Then, Daq supply connect to the relay which control the power supply? Im quite confused, try to make things clear...
1 more thing about the Daq...im actually curious on can i actually use the DIO to direct send a signal to the h-bridge instead?
Regards.
Message 3 of 10
(4,751 Views)
Hi Wyatt,
sending out a signal is no problem using DIO - but you have to decide between a TTL-compatible signal using some milliamps and an output driver supplying 200mA...
Message 4 of 10
(4,745 Views)
Hi Gerd,
Which mean i can skip the implementation of the relays and stuff and focus on the TTL signal to my h-bridge?
Sry for all the electrical question. Im not good in it.
Message 5 of 10
(4,682 Views)
Hi Wyatt,
well, without seeing your layout I can't recommend anything for sure... I only see that you have a source capable of supplying 30mW and your sink will need 300mW (from your first post). That's a big discrepancy! There's also a big difference between powersupplying a circuit and sending a signal to it...
Message 6 of 10
(4,544 Views)
Hi Gerd,
My project is about controlling a car model with a PDA Bluetooth. For the car model part, i need to connect Daq(CF-6004) with H-bridge driver (L293D) to send the signal to run the DC motors (1st motor for Left/Right 2nd motor for Forward/Reverse). Controlling Part, remote controlling the car model with another PDA via Bluetooth.
From the 1st post, I try to connect the Daq with H-bridge i made. But, last week i burned my H-bridge on the attempt and now i switched to use L293D instead. Hence, The specification of the signal might vary. For the L293D i used i need  2 supply for it, 5 V for the IC itself another 6 V for the DC motors. Supply from Daq 3.3V and 0.01 A.
About powersupplying circuit and sending signal i got no idea at all. I can't think of anything when i panic, especially i left 1 month for the deadline.
Please guide me.
Message 7 of 10
(4,533 Views)
I know that the problem im asking not really related to LV. But, please someone give me solution for this.
Thanks.
Sincerely,
Wyatt
Message 8 of 10
(4,382 Views)
case closed. problem solved.
thanks for the help.
Message 9 of 10
(4,256 Views)
Please post how you solved the problem so that anyone searching for a similar problem in the future can learn from your experience.Smiley Wink
Message 10 of 10
(4,243 Views)
