Connection Labview 6i and Simulink 4.1 model ?
I would like to know how to communicate between a Simulink model and a
Labview program in a real time way. Passing through TCP/IP seems
possible. Could you please help me if you have already experienced it.
The labview toolkit for Matlab/Simulink is not interested for me because
the dll-Methode is not a solution for my problem, i want to run my
simulink model dynamically under Labview and this is not possible with
the new labview toolkit. Some keywords for this
problem are(tcp/ip,DDE....). Also it is not relevant for me to use
Matlab as ActiveX Server for the data commutation between Simulink
and Labview because it is very slow.
Thanks in advance
Mondher
(2,872 Views)
I tested the simulation interface. It seems to work fast.
I think the speed of interchange can change depending the direction of exchange of data, from or to simulink sink.
Have program a realtime simulator for powerplants written in C++.I translates the RT sim to NI components and software (Labview).
My rt pxi turbine simulator for simulating grid incidents was succesfully used in a nuclear plant in 2006.
Look at http://sine.ni.com/cs/app/doc/p/id/cs-755
(2,847 Views)
