Connection Lost -1073807194 in VISA
 I am using silicon labs USB to USRT converter for serial communication. When I am using VI 'Testing-V0' (attached) then after 2-3 successful communication I am getting -1073807194.
For crosschecked I am opening and closing the VISA resource at the time of reading only(attached VI is Testing-V1 ). Then also I am getting same issue but frequency is less.  But in tera term it is working fine
I checked at MAX and there also I am getting same issue. I am using WIN7, LV2011, VISA 5.3.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,917 Views)
Where exactly is the error comng from? The flush or the read? Also, why are you constantly flushing the interface?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,880 Views)
