Connection four fields to one
you know tell me what is wrong?
if each type separately ... it works
when I connect an extract of the four fields into one so nothing happens...
(3,328 Views)
Try building an array with concatenate inputs, interleaving will give you an array with length equal to the shortest input, probably zero.
(3,325 Views)
thank you for the advice,
problem is that now the field is 2D (see Figure)
does not display the names underneath....
I need write items in order underneath
(3,314 Views)
As Darin said, use concatenate inputs.  Right-click the build array and select it from the pop-up menu.
EDIT: Or, just use the concatenate string VI in the strings palette.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,311 Views)
I understand ....it works
Thank you very much...
(3,302 Views)
