Connection limit to a webVI
Hi everyone,
We are trying to include more webVIs in our developments so we are playing with them to figure out what's possible or not.
By our tests, it seems only three clients can connect at the same time to a webVI.
Is it a fixed limit ? is there a way to increase it ?
JP
LabVIEW Architect - Founder and CEO - Phalanx
Tout le succès d'une opération réside dans sa préparation. - Sun Tzu
(2,613 Views)
Hi JP,
You shouldn't be limited to 3 clients; I'm surprised to hear that is what you're experiencing. Can you describe how you have your system set up? Where are you hosting the web app (NI Web Server, LabVIEW Web Server)? What do you experience when you try to connect the 4th client? What is your WebVI doing?
Rita Prather
Software Product Manager
rita.prather@ni.com
(2,572 Views)
I answer in place of JP, I'm part of his team development.
The application (a basic hello world with tags on clients and server) was hosted on NI Web Server on local configuration (through the same network).
We are all on Windows 7 or 10.
The 4th client just cannot acces the website. After I disconnect my phone, the client can access the application.
We made this operation several times and encounter the same problem.
Regards.
(2,545 Views)
Hi there,
Sorry for the delay. This doesn't sound normal, so I would recommend reaching out to support if you haven't already. They will probably ask you to reproduce the issue immediately before generating a report from the Server Configuration Utility so they can check out the logs.
Rita Prather
rita.prather@ni.com
(2,381 Views)
