Connection of eZdSP F28335 card with Labview.
How do I connect the F28335 card with labview to program. The card is connected by serial and via USB.
I need to program three epwm for the control of a three phase motor.
Is there an example VI program?
(2,483 Views)
You know you cannot program that card with LabVIEW?
So I presume you have already a firmware installed in it?
So use the documentation of that firmware to know the communication protocol of that card and then use it...
But if you want to program that with LabVIEW, I suggest you to go back to the design stage of selecting your hardware or your IDE...
Benoit
(2,451 Views)
The port you show in your second picture does not appear to be a virtual COM port but rather a proprietary USB communication device for the software that comes with this device. At least over that port you won't be able to communicate from within LabVIEW with your device, unless you have a DLL with API documentation and are prepared to write such a VI library using the Call Library Node. Unless of course the manufacturer of that card already has such a library (miracles sometimes happen, but don't hold your breath for it).
As already mentioned you can not use LabVIEW to program that card directly anyhow, but from your wording I didn't think that was what you were trying to do. If you can find a way to communicate to that card over RS-232 (those two connectors on the other side are serial ports or just some IO?), you can definitely cummunicate with the card by using the VISA functions in LabVIEW.
Rolf Kalbermatter  My Blog
(2,434 Views)
