Connection to a distant VI
Problematic:
I want to access from one PC to an autonomous application installed on another PC through an Ethernet connection with a web browser.
Trials:
LabVIEW is installed on PC1 but isn’t on PC2.
When I try in local on PC1 it works.
When I try from PC1 (web browser) to PC2 (application) it works.
But when try in local on PC2, or from PC2 (browser)to PC1 (application) it doesn’t works.
HTML page displays “download of front panel. 0% of 0 bytes” and stays in that state.
I suppose that a LabVIEW module must to be installed on PC2. I have already install :
LV Web Services
NI LV Web Services Runtime
NI LabVIEW Run-Time Engine Web Server
NI LabVIEW Web Server
Server NI VISA
But the problem is still here
Somebody have any idea?
Message 1 of 10
(4,603 Views)
There is a chapter in the LabVIEW help about remote front panels:
Viewing and Controlling Front Panels Remotely
On the Web:
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 2 of 10
(4,584 Views)
Thanks but i have already read this paper but it doesn't help.
Any ohter idea ?
Message 3 of 10
(4,566 Views)
up
Message 4 of 10
(4,529 Views)
you will need to have labview web browser plugin installed for the browser. Is the plug in installed?
Message 5 of 10
(4,523 Views)
I don't know.
Is it included in the LabVIEW module i already install ?
If no where can i find it ?
Thanks.
Message 6 of 10
(4,516 Views)
Message 7 of 10
(4,507 Views)
plugins where already installed.
Message 8 of 10
(4,495 Views)
Which browser are you using? How have you verified that the browser plug in is installed?
Message 9 of 10
(4,493 Views)
I try with explorer (6.0) and firefox(3.6.6).
And Yes pluggins are installed.
Message 10 of 10
(4,482 Views)
