Constant Documentation LV 8.6 Bug?
If you right click on a constant and go to properties, then select the documentation tab, type something in and select OK it goes away.
You have to right click and select description and tip then type and it will stay.
Is anybody else seeing this problem?
You still should be able to do this under the properties tab.
(4,011 Views)
Looks like you found a bug in LabVIEW 8.6. It works just fine in 8.5.1.
(I reported it here)
Message Edited by altenbach on 09-29-2008 11:41 AM
(3,988 Views)
If you press OK in both dialogs, the dialog always goes away. At least in my
8.5 version.
(3,952 Views)
@Wiebe: I think he's talking about the documentation text that goes away when clicking ok.
(3,949 Views)
"dan_u" <x@no.email> wrote in message
news:1222769422572-784717@exchange.ni.com...
when clicking ok.
I kinda suspected that, but where to lazy to investigate...
(3,939 Views)
This issue has been reported to R&D for further investigation as CAR: 128314.
Kevin S.
(3,911 Views)
