Constant-Q transform
Does constant-Q transform function exists for LabView. Constant-Q transform is Fourier-like transform were the frequency resolution decreases with frequency, i.e. width of frequency point is proportional to frequency (in regular FT it is constant and =1/T).
(3,939 Views)
Looking around, I found this related information:
http://zone.ni.com/reference/en-XX/help/372416H-01/svtconcepts/svbandwidth/
This computation is part of souidn and vibration toolkit.
Karine
(3,900 Views)
Thank you. Indeed it is functionally equivalent. I looked into the function, it looks like it is realized as a filter bank, which is, probably, not very efficient computationally. However, I can not be sure, since at some level it is password-protected.
(3,893 Views)
Yes you can't get under a certain mevel of hierarchie. It should be posisble for you to  implement the desired fonction using basic LV components.
(3,887 Views)
