Constant Voltage output from DAQ
I am currently stuck. I need to have a DAQ interface through LabVIEW and output a constant Voltage. not a signal. Basically, I need it to activate a relay once I activate it in LabVIEW. is this even possible? I have both a Digital IO DAQ and an Analog IO DAQ.
(2,635 Views)
Hi Jordan,
which DAQ devices are we talking about?
Do you use DAQmx devices?
Generic answer: yes, it's possible. The DAQ device needs to supply enough current to drive your relay - or you use an amplifier...
(2,628 Views)
What relay and what boards are you using?  You might have an issue with output current not being strong enough for the relay.
(2,627 Views)
I am using an Altronix Phenolic or Fiberglass Relay Module 6/12VDC 120Ma DPDT.
(2,618 Views)
Hi Jordan,
what about the questions on your DAQ hardware?
Any datasheets of the relays?
(2,583 Views)
You want to "activate a Relay", i.e. you want to deliver a digital signal, "Relay On"/"Relay Off".  You can generate this with a D/A converter, but it is much simpler and more logical to do this with a Digital I/O port.
However you generate this (digital) signal, you need to use it to activate a Relay, which means it must generate sufficient current to drive the relay.  Many DAQ devices, particularly DIO devices, have rather low Current drive, while many electro-mechanical devices, such as Relays, require modest Currents.  This can often be accomplished by a one-transistor circuit and an external 5v Power Supply.  Talk to an Electrical Engineer (beyond my expertise!).
Bob Schor
(2,550 Views)
got it! thank you so much for the help. I utilized the DAQ assistant to send a logic high of 5V to the relay when I need it to activate
(2,542 Views)
